I have question on bonding the wet niche housing. I know you bond the terminal on the outside of the niche for both low voltage and high voltage but if the housing is all pvc is it necessary to bond the terminal on the inside if its 120v. Inpector told a client that its not necessary . I don't see that in the bonding section. Is something new , I'm using the 2014 code book. Thanks
