inspector23
- Temecula, CA
Getting long in the tooth and short in the memory. :roll:
I am trying to remember if there is a code section that requires conductors be rated for wet locations if spliced or terminated in a NEMA 4 or NEMA 3X junction box or disconnect.
I know here in SoCal we always required the installer to use UF rated cable instead of just romex when going thru an exterior wall to an air conditioner disconnect, for example. Or for front and rear required exterior receptacles mounted in an FS box in single-family dwellings. But dang if I can remember a code section to verify it. :happysad:
I can find the code sections for conductors in a raceway compliance (300.38), (310.10C). But I cannot find one for conductors in wet location-rated junction boxes and disconnects.
I am going to go ahead and thank you now for your help rather than risking to forget to later!
Thanks,
Mike
P.S. You would never know this is my first question since the emojis were an option, would you? haha :thumbsup:
Thanks,
Mike
