This is news to meI went and looked up an image of a phase converter and I believe hillbilly1 & ActionDave nailed it.I'd even bet on it :thumbsup:
dick
Nobody knows where the other end of white and bare are connected. Maybe the electrician was doubling down on bonding but did not have any green tape.What I do see for sure is that the neutral and the grounding conductors are both bonded to the cabinet, a definite no-no.
Red connects to blue through a set of capacitors
Black connects to blue through a set of capactitors
Black connects to yellow through a set of capacitors
Yellow connects to blue if the relay is closed
The relay coil is fed by red and black through a block which is a solid state something.
There are two extra knockouts in the bottom of the 3R cabinet.
Supposition -- this a phase assist with the input wired and the output not wired.
Supposition -- it was not wired by an electrician who understands the different between and neutral and grounding.
To help remember which is which I always use this handy mnemonic memory aid- Brown equals start and silver equal run because even though r is before s in the alphabet, b is before all of them...... The brown caps to the right are the start caps, and the silver are the balancing run caps. ...
You are looking at a banks of capacitors with bleed resistors.Could anyone help me understand what this does?
Thank you
