jtruncale
- Port Arthur, Texas, United States
Hello all,
I work in an oil refinery and we have many small 120VAC control relays such as Potter-Brumfield icecubes all over the plant controlling everything from lights to small MOV's. Most applications do not present a problem when a $50 relay fails, but occasionally we end up shutting down something that costs the plant thousands, if not millions of dollars.
Naturally, most of these failures occur when a relay has been switching too often, say.. once a minute for 6 months. Of course, certain design changes can usually be made to remedy the issue of the constant switching, but I would like to hear from some different folks on what relays they have used in the past (brands, types, models, whatever) that have proven to be the most reliable in their own fields.
I have looked into solid-state relays and they seem like a good solution, but I am not familiar enough with them to confidently recommend them for use in our plant. I understand they can get pretty hot and may have other issue unbeknownst to me.
Any and all suggestions are welcome! Thanks!
