Shahzad
- Canada and USA
- Electrical Engineer
Hello
I have a main incoming breaker 5000Amps which feeds a low voltage 400V, 3 phase panel board. This bus is pretty much full. I need to put a breaker to feed 500kW (800Amp) resistive load. I have following question.
(1) Do I need to go with 1.25x800= 1000 Amps Breaker (Insulated Case Circuit Breaker) or a normal 1000 amp molded case thermal mag breaker?
(2) Or I should with exact load 800 Amps thermal mag Molded Case Circuit Breaker?
(3) Do I need a softstarer for 800Amp resistive load or not needed? Any recommendation how can I reduce the inrush? It is on 400V, 3 phase system.
(4) Do I need to buy a new panel and bolt it with existing on the same incoming? or do I need to have separete incomer?
