What compound(if any) to use on 3 phase circuit breaker terminals to bus bar.
steve61
licensed Electrical Contractor
Nebraska
I am replacing a 20 amp 3 phase circuit breaker in a 460 volt panel. I am replacing it because one of the bus bar connections had some arcing and lightly burned the bar on the breaker. Is there any compound that I should consider using on the breaker connections to the bus bar ? Thanks, Steve Wiese.
Schneider Electric has tubes of PJC (plug-on joint compound) for these types of connections. I think they say to use it every time a breaker is moved.
