What constitutes a switch?
wrobotronic
Colorado
Hi again,
I had an inspection today in which I failed it because there was no illumination on an exterior door. 210.70A2b calls for a "switch controlled lighting outlet". Can this "switch" be a motion or dusk/dawn sensor or does it have to be an actual single pole switch? My gut feeling is that a switch has to be able to control the load in question on demand, thus a motion sensor is not sufficient Thank you in advance.
Don't you still need a disconnect means (switch) for that motion controlled light ? A lot of the motion sensors have an override where you operate the switch "off-on, off-on" within 2 seconds and the light remains on.
There are more means of automatic control then just motion sensors.
The override switch for the motion sensor you describe could be a requirement of the listing instructions of that controller though.
