esca9lante
- Colorado
Last week at Coors Field in Denver a heavily loaded down-running escalator inexplicably sped up and dumped people in a heap at the bottom, causing many injuries.
Initial investigations reveal no gears or transmission (mechanical) parts were broken or stripped, but it is believed that there was more weight on the escalator than it was designed for (300 pounds per step). So now the investigators are looking for answers, and all the escalators at Coors Field remain deactivated.
I would like to offer this as a possible reason for what happened, and I'd like to hear others' opinions on it.
I assume the motor driving the escalator is a typical induction-type, probably running at 480 volts. In my limited experience with induction motors, if you load one down (my dad had an old table saw that had one of those) to the point where it overloads the motor, it stalls; it doesn't just get slower and slower as more load is applied. So wouldn't it be possible that the exact opposite happened with the motor on the escalator? An induction motor keeps a more-or-less constant speed no matter what the loading is, until the induction is broken. If the motor is being pushed to go faster, it will hang in to the induction for awhile until the pushing load exceeds its ability to hold back (breaks the induction), and then it free-wheels with no speed control at all.
What think you all?
What think you all?
