so I should know what the stat terminals do, actually i thought i did
i installed a 240v toe kick heater in our new bathroom
i source it from a cabinet w a 2p relay [24v coil]
Toe kick works great when you pick the coil closed
now i install the nest thermo stat
he starts to give me the n260 code
oh, he needs a common wire...
i only needed two wires to pick the coil before, but i added a 3rd wire for the common.
so now I have [lets call call ém tx1 & tx2]
switched tx1 at stat [in this case red] landed on the red post
steady tx1 at stat [in this case yellow] landed on the C post
steady tx2 at stat [in this case white] landed on the W post
I can pick the coil direct to the TX and the relay and the heater are fine.
Just too dim to see the smart switch in the stat :/ it no worky.
what do the R C and W posts do?
I thought
R was the switched hot which I have [TX1]
theres only R, not Rh and Rc
W was the return path for R [TX2]
and
Y is the steady version of the switched TX1 landed on the common post
thanks guys
I thought
and
thanks guys
