Designer69
these are the main terminal connections for a 13.8KV motor. I always forget the industry name for these... terminal plates? terminal blades? not sure can someone help? please see attached image
thanks
Are those not bus bars?
Do you have a better image.I'm trying to put this together in my mind.The 3 stud bushings are integral to a 3/c Pothead which has an UG feeder to a source voltage and will have a flexible braid connection from the bushings to the 4 hole connections of the bussing,the busses route down thru the CT's and in to the motor windings.
This a SWAG until I see a better defining image.
dick:-?
Here is a picture of a terminal adapter. It is the piece between the bus bar & the terminal for the cable connection.
