ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
I'm going to keep this hypothetical with no names attached, since I know that some AHJ reps read this forum.
What do you do when this happens? Say you are dealing with an AHJ who has a requirement for a way to build a certain type of PV system which is not called for by the NEC, and which causes those systems to be built in such a way that increases the cost of the system significantly, seriously inconveniences the customer, and introduces unnecessary bureaucratic blsht which adds weeks to the time between the sale and the system initialization. Say you have had extensive discussions with the AHJ regarding the matter and they justify their position with hand waving and generalities. Say you send them documentation from UL which confirms that an easier, less expensive, and more customer friendly way of building the system is both safe and fully NEC compliant, to which they reply with silence.
Say you are a design engineer caught between your protesting sales and installation departments (including your boss) on the one hand and the AHJ on the other. What do you do?
I'll hang up and listen.
