mjf
Often when replacing a switch or receptacle in a steel box, I find the old NM cable installed with the bare ground wrapped back around the sheathing. The cable/bare ground is clamped down which bonds the steel box.
Just curious as to if this was ever actually code compliant....as I said, I see it often.
I'm also curious as to what do others do in this situation?
Do you just pop the new device in with a green pigtail to the box?
Do you loosen the clamp, unravel the bare grounds, hit the new device, and re-bond the box?
Do you just drop back 15 and punt?
