Re: What do you guys do?
Originally posted by infinity:
This sounds good but can they differentiate between conduit and rebar? I've seen some decks where you couldn't core a 6" hole without hitting some rebar.
I don't know - they say they can tell the difference between copper pipe and steel pipe. Maybe the tester will also indicate a difference in the density of solid rebar and hollow conduit? Of maybe with practice you can tell the difference in the diameters?
And rebar should be spaced fairly evenly -- you should be able to spot a conduit on a spacing that isn't likely to be rebar?
No doubt that you will encounter slabs with rebar on 6" spacing (or even double mats), but that would be the exception, not the normal. Most slabs have single-layer rebar spaced between 12" and 24" OC.
Anyway, for under $200 the instrument may be able to help you miss any steel object in the concrete, whether it's rebar or conduit. That would seem worth the price if it works.
I'm sure there will be slabs that it just won't help on, but if it helps on even 50% of them it would be worth the price.
Also, I didn't address some of the other points that copper123 asked in his original post:
I would definitely have a clause in your contract or scope of work that if you cut or damage
anything in the slab, then the owner is responsible for the costs of repair (if repair is required). If the owner wants to make you responsible, then you should include the costs of having the slab X-Rayed in your bid price (maybe as an add alternate?) or in your rebillable costs if you are working T&M. Present it so that he has to make the choice -- pay for X-Rays or take the risks himself.
And I wouldn't trust any as-built drawings. If the owner gives some to you to use, the accuracy of the drawings is his responsibility. How would you know if they are accurate? It only has to be off a half-inch.
I'd mark the proposed drilling locations and have him agree with them (sign off) before you drill. I'd make sure it was clear that if you hit anything, it will be his responsibility to pay for the repairs.
I agree that you should make the repairs to any electrical work that is damaged, but it should be at the owner's expense, not out of your pocket.
You better make sure they don't have any in-floor slab heating systems -- that would probably be a real pain to repair.
