as I am going the NEC and by reading posts and talking to inspectors and other contractors a comment that comes up alot is "it has to listed product". Now my question are:
Out all of the items, equipment, hardware that we install which has to be listed?
for example the EMT strap that just came up in previous forum. the 1 hole straps do not have to be listed. Then again the AHJ says you have to use a listed product to support the EMT
2nd example: when using grounding screw to bond the metal box. The grounding screw does not have to be listed just for grounding, yet some AHJ think the green screws have been listed & designed just for that purpose.
3rd example/question: Supporting NM cable. I can install 1 hole strap and use zip ties to strap the NM cable to the 1 hole strap. Yet some AHJ will fail the inspection.
4th example: Sheetrock screw, we all use them for other tasks other than sheetrock. Now, is that listed as a fastener or it is listed strictly for sheetrock?
What items/equipment have to be listed? when does an item has to be listed? who determines that a product has to be listed?
