Fulthrotl
~Autocorrect is My Worst Enema.~
- E
I'm with everyone else on solid wire above #12 or maybe #10. Also, mixed feelings on pulling in conduit vs terminating under screws.
What I would like to know is how you put stranded wire in an Ideal push-in or Wago connector. There specs list the allowed wire sizes in both solid and stranded.
I used to "tin" the wires in control circuits to use on "wago" type connectors. These connectors were French made and were around long before Ideal's or Wagos.
I thought about tinning for these connectors (Wagos/Ideal) until someone pointed out the risk for corrosion, although I've seen tinned wires that I did that were at least 15 yrs old with no corrosion.
Don't mean to derail the thread, but it is solid/stranded connected, no pun intended!
use a good pair of needle nose pliers, strip 1/2" of the insulation, grab the wire right at the end
of the insulation, and shove it into the wago. once you get the hang of it, it works fine.
i only use wirenuts when a wago won't work, like finely stranded wire.... i've been using
nothing but wagos and stranded wire for about 3 years now, and have yet to have one go
south.
