Eddy Current
Ive never heard the term before.
Typical conduit connectors are boss fittings. "Boss" as used in this sense is a generalization meaning there is an enlarged body part which prevents complete passage through a smaller-sized hole; a shoulder around the body.Ive never heard the term before.
You may be correct, but I was taught otherwise.
http://www.forefrontstudios.com/tips_n_tricks/TnT-Weldolet01.pdf
That sounds like an electrical example of a more general situation in which a "boss" is a lump of metal, often with a threaded hole, which is brazed or welded to a tube or other structural member so that something can be mechanically attached without reducing the integrity of the member by drilling a hole in it.Basically, an electrical enclosure or fitting with a "boss" has integral threads, usually five or more. A typical conduit body or FS box are boss type. It must be an integral part of the enclosure; i.e., a hub fitting would not make a Type 12 enclosure a boss enclosure.
My own experience with the term electrically comes from Section 502.10(A)(1)(4).There is another more general reference in Section 300.4(G) Exception which I never personally refer to but it is there.1boss
noun \ˈb?s, ˈbȯs\
Definition of BOSS
1
a : a protuberant part or body <a boss of granite> <a boss on an animal's horn>
b : a raised ornamentation : stud
c : an ornamental projecting block used in architecture
While I agree with your comments, the OP is regarding a "boss fitting", which enclosures, boxes, and conduit bodies, or parts thereof, are not...Boss is indeed a general term defined in Webster's Eleventh Collegiate Dictionary as:
If unsuccessful, please at the very least come up for air on occasionI gotta get my mind out of the gutter
:happyyes:
Remember the old saying: "Great minds run in the same gutter." Or something like that. :lol:I gotta get my mind out of the gutter
:happyyes:
Assuming the OP is regarding an electrical fitting, plumbing (or pipefitter) terminology does not applyDont worry. I have also not heard it before. One of my friend provides plumbing services he told me about boss fitting. There are fitting tools are available like Boss Clamp 2 Bolt,Boss Ground Joint Double Spud,Boss Hose Mender,Boss Holedall Fitting. You can consult with professional plumber which provides plumbing services.
