Confused with classifing a piece of equipment. When there is a piece of equipment, when is it considered an appliance (article 422) and when is it considered a motor (article 430)? With respect to choosing the OCPD. Here are a couple examples:
1. Sump pumps, motor or applinance.
2. Exhaust fan, motor or appliance.
3. Garbage disposer.
Now, regarding the garbage disposer, this would be very similar to a sump pump and a garbage disposer is specifically called out as an appliance per 422.16B. So since it is an appliance, it is a motor-operated appliance. Choosing the OCPD would be based on 422.11(G). However, this says where the overcurrent device is separate from the appliance, it says it shall be marked on tha applicance. Typically, a garbage disposal does not have a breaker on the side of it (the overcurrent device), nor do the list the breaker size on the "appliance"? Don't understand?
