electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
What do you use them for? Hopefully this will fill up the 100 character limit. I guess not, I'll type a little more.
Yes I am familiar with those.Are you familiar with the 0-10 volt dimmer for LEDs? They're usually the high out put type of light. They require two additional wires from the dimmer to each light.
I don't care if one is converse phase dimming or uses a flux capacitorCL and ELV are both forward phase dimming. MLV is reverse phase dimming.
I don't care if one is converse phase dimming or uses a flux capacitorwhat is the practical difference between a CL and a ELV? ELV seems to have a neuter wire, why doesn't a CL? I want all the answers RIGHT NOW!
Yes, elv dimmer has neutral wireI don't care if one is converse phase dimming or uses a flux capacitorwhat is the practical difference between a CL and a ELV? ELV seems to have a neuter wire, why doesn't a CL? I want all the answers RIGHT NOW!
I've no data on it, but it wouldn't surprise me if reverse phase dimmers would also be less stressful to LED lamps and ballasts because it avoids the fast rising voltage of the forward phase type when the SCR fires which can cause a large current spike on capacitors and semiconductors . And having less electrical stress is likely to promote a longer lifetime for the lamps and ballasts."Reverse phase" dimming can be used for almost everything EXCEPT magnetic low voltage transformer loads. Since some 99%+ of dimmers sold are forward phase, the vast majority of LED ballasts are designed to operate with forward phase, but operating on reverse phase can drastically reduce humming/buzzing on LED lamps or LED ballasts and even incandescent lamps prone to buzzing sound otherwise.
I also suspect that the EMI would also be lower for the reverse phase type.
