G GlennH Member Jul 17, 2013 #1 On a job where the specs call for all exposed low voltage wiring in an attic to be in conduit. NEC seems to define exposed as "on or attached to the surface" Would you call wires completely under the insulation as exposed?? TIA
G Gregg Harris Senior Member Location Virginia Occupation Electrical,HVAC, Technical Trainer Jul 17, 2013 #2 GlennH said: On a job where the specs call for all exposed low voltage wiring in an attic to be in conduit. NEC seems to define exposed as "on or attached to the surface" Would you call wires completely under the insulation as exposed?? TIA Click to expand... If it was inside a wall cavity it would not be exsposed, your example would be considered exsposed
LEO2854 Esteemed Member Location Ma Jul 17, 2013 #3 GlennH said: On a job where the specs call for all exposed low voltage wiring in an attic to be in conduit. NEC seems to define exposed as "on or attached to the surface" Would you call wires completely under the insulation as exposed?? TIA Click to expand... Yes I would because they're not protected by a raceway, so in this case they are exposed to Physical damage.
