vinod
- Saudi Arabia
Kindly define the voltage range of High Volt (HV), Medium Volt(MV) and Low volt (LV)?
vinod said:Kindly define the voltage range of High Volt (HV), Medium Volt(MV) and Low volt (LV)?
vinod said:As far as I know that,
LV is <600V
MV is >600V to <38KV
HV is >38KV to <115 KV
Extra HV is >115KV
Am I correct?
weressl said:It is best to go to an authorotive source. (Wikipedia may be right but it is NOT and authority.)
IEEE Std. 141 also known as the Red Book
120-600V Lov Voltage
2400-69000 Medium Voltage
115000-230000 High Voltage
345000-765000 Extra High Voltage
(This way you can cite the authority, not Jack from the Mike Holt Forum....)
Dennis Alwon said:Where does 24Volts fit in with IEEE--- extra Low voltage????
sreeja said:Is it internationally accepted range?
Doesn't that have something to do with the coriolis effect and positive electron spin?:roll:dbuckley said:...the 110KV lines we have here in NZ dont fit into any official category....
