electricus
- wisconsin
Want to know what is suggested for a work shop.
The Cooper link is, as you say, for their products.After reading that article, they guy that wrote it makes it sound like all other articles dance around the point, but he is not going to. Well he does, he uses a lot of big words, and in the end basically says that once everything is set up then take a foot candle reading and make adjustments. What I got out of it is that lighting is an experiment. I get that, but I wanted to try to get it right the first time during the rough in stage and not have to make difficult changes once everything is finished. Let the experimenting begin.
Got it downloaded, but not user friendly to the layman, and unless one is using Cooper products, or know which model is closest to what you have, this is a tough on to use. Did some more research and came up with the general consensus that most people out there have 2 to 2.5 watts per square foot, or 80 - 100 fc. One would need a foot candle meter and this all testing after the fact, the height of the meter off the floor also makes a difference.
One thing I did not consider off the bat is that nothing is 100% efficient. The original amount of florescent strip fixtures I was going was not enough. I figured more the get me to 2.5 watts/sq. ft., but then realized if they only output light at around 90% once used for a while I would need to add another fixture or two just to make up for the inefficiency. Hope that part helps for who ever is trying to figure lighting on there project.
I think I have it figured out and have a plan I'm going to go with.
