watabull said:
1) Common knowledge so I will know in the future and don't have to ask silly questions.
This are no such thing as a silly question. However, we can provide silly answers to reasonable questions.
2)Will a 208v 8kva(1 or 3 phase) griddle cook(be ruined, sorry for the pun) on a 120/240V 40 Amp circuit?
An appliance must be marked according to the voltage it is rated (422.60(A)) and connected to the voltage for which it is rated (110.3(B)). To connect a 208V range to a 240V source would be a listing violation, unless the range is marked to be connected to a 240V source as well.
It may not hurt the range, but if you connect it to the wrong source you are taking responsibility for the outcome, IMO.
Edit to add: I forgot the original question!
The difference between 208V three phase, and 240V single phase, is how the voltage is derived.
240V single phase is obtained by taking a single leg of three-phase power.
208V three phase is obtained by taking two legs of three-phase power.
In a 120/240 single phase system, the midpoint of the secondary side of the tranformer is tapped and grounded to create a neutral. From the midpoint to any line reads 120V, and from line-to-line (the full voltage) reads 240V. Imagine planting a black flag in the sand, walking 120 steps in a straight line, planting a white flag, and then walking another 120 steps in the same line to plant a red flag at the end.
In a 120/208 three phase system, the neutral is at the center of three phases from the utility. In this case, using the walking in the sand analogy: A white flag is planted in the center. You walk 120 steps away from the white flag, and plant a black flag. You return to the white flag, turn 120 degrees, and walk another 120 steps, planting a red flag. You return to the white flag, turn 120 degrees, and walk 120 steps to plant a blue flag.
Once this is done, you face the red flag from the blue flag, and count your steps as you approach it. There are 208 steps between flags.
If that doesn't make sense, you're not alone in the universe.
