what is the difference between FM7 FM8 AND FM9 CONDUIT BODIES
http://www.emersonindustrial.com/en...-conduit-bodies/fm7-bodies/Pages/default.aspx
FM7
Grayloy™ iron or copperfree aluminum construction with epoxy powder coat finish, stainless steel screws, neoprene gaskets
Grayloy iron bodies with cast covers and gaskets are approved for use in wet locations
Form-IN-Place covers with integral gasket are approved for use in wet locations
Unique Wedge-Lok™ clip cover design allows easy removal without damaging the conduit body
Flat back design fits flush against flat surfaces for more stable installation and provides more interior room for wire pulling and splicing
Interchangeable with competitors’ Form 7 bodies, gaskets and covers—applications and installation dimensions are identical
FM8
Grayloy™ iron construction with epoxy powder coat finish, stainless steel screws, neoprene gaskets
Covers with gaskets are approved for use in wet locations
Interchangeable with competitors’ Form 8 bodies, gaskets and covers—applications and installation dimensions are identica
FM9
Copperfree aluminum construction with epoxy powder coat finish, stainless steel screws, neoprene gaskets
Covers with integral gaskets are approved for use in wet locations
Domed covers provide extra wiring space
Interchangeable with competitors’ Form 9 bodies, gaskets and covers—applications and installation dimensions are identical
