Hi folks...
I just want some clarification regarding the right connection of 220/110 volt in the USA.
For 220/110V 3 phase 4 wire, I believe this is wye connected with neutral.Does the neutral also to be called ground or earth?If yes, the neutral conductor shall be bonded to the ground electrode of the premises(building/house/etc.).
For 220/110V 3 wire, I believe this is single phase transformer connected as if to be view as open delta because of its neutral.Does this neutral in float or does it also connected to the earth or grounded.If yes, floated, it must not be connected to grounding electrode of the premeses.
Thank you and I hope to be enlighten to this as well as other may be.
wyedelta
wyedelta
