What is the thin metal wire in a AC Bx for
The electron man
Nyc
I know that thin wire has something to do with the grounding but how important is it ?
I was installing an AC bx and that thin wire broke off , I can't strip more of the Bx should I just run a new cable or its not a big deal ?
It's there for bonding the sheath to make it an acceptable equipment ground. It need not extend beyond the jacket or be terminated No problem that it broke
The thin bonding tape just shorts together the spiral wound armor jacket so that the fault current can travel in a straight line instead of around the conductors which can cause the jacket to become an inductor and not allow the OCPD to open because its doesn't see the fault.
Full disclosure - not an electrician - but growing up around real ones years ago I was taught to wrap the bonding strip back around the BX because it helped hold the anti-short bushing in place.
No idea if that was a local Brooklyn NY thing?
When I was an apprentice we were taught that was the reason why the strip was in the cable. It was only there to hold the anti-short bushing. :rolleyes:
That's how my journeyman thought me to do it
That's how I was taught also and all I ever saw. Way back when the new code went into effect (50's) that required the "new" AC with the bonding strip, I was told that the inspector wanted to be able to see it so he knows that you were using it. That's why we wrapped it, so he can see it outside the box.
But yeah, no sweat if it breaks off.
-Hal
When I was new to the trade, maybe a year in, I had never seen nor knew what AC cable was. IT was never used in my area. I went down to Maryland to do some electrical for a friend of a friend. Came across some AC cable and was baffled by the super small flimsy "ground". I remember carefully wrapping it around a ground screw and trying not to break it....... 🤣
