MJHaleakala
New member
- Puunene, Hawaaii
I was taught that when tying PV onto the buss of a meter combo the maximum tie in is limited to 120% of the bus rating (705.12(b)(2)). I was also told that this 120% rule applies to tapping on to the load side of the main service disconnect with the wire ampacity of the wire as the limiting factor. The reason I was given for this is that if you tap 30A of PV on to a 100A conductor, then it is possible for that feeder to pull 130A without tripping the main over-current protection. This makes sense if the house were to draw 130A while the PV was at full production, but this seems to be a bit of a stretch from any real world situations.
I have not been able to find anything in code to support this. It seems to me that by code we could tap 100A of PV on a 100A main.
What is the truth about using tap rule to tie in PV? And Why?
