What is this?
IBM used that type of cable, called twinax, for their synchronous data terminals including POS devices. They used a polled hierarchy so the data line toward the central controller had to be interrupted in order for a device to transmit without interference from upstream.
The bus or ring came in on one cable and out on the other, hence the need for a bypass switch when a device was removed or under repair.
We were still installing IBM token ring connectors and cabling as late as 1999. An advantage they had over the OPs connectors was that they self bypassed.
Twinax! I was looking at that and some neurons were firing in the back of my brain, but I could NOT for the life of me remember what it was called. Thanks GD, saved me from a 3AM wake-up recollection.
