- New Jersey
- Journeyman Electrician
It is a factory installed jumper so the NEC ampacities do not apply. Even if the NEC did apply I think you could use Table 310.15(B)(17).That makes sense but why a #1/0 jumper for 200 amps, wouldn't the terminals be rated for only 75° C?
Also for AC would you remove the jumper?
Being that is a factory jumper, that disconnect may not be listed for AC use. If it is listed, I see no reason to remove the jumper.
You never cease to amaze me. :thumbsup:
And yeah, Don is pretty amazing.
I see that kind of thing in pump panels, panelboards, etc. all the time. Factory installed (or even factory supplied but field installed) leads between components that are otherwise smaller then what you would have to use if assembling same components that are not part of a listed assembly.It is a factory installed jumper so the NEC ampacities do not apply. Even if the NEC did apply I think you could use Table 310.15(B)(17).
I agree, does anyone have a document that shows this? I've been poking around but am coming up empty and I know that people will be asking.
You watch a demo of a knife switch open a 2600 watt load at 220 AC and at 220 DC in this youtube video.Switching devices primarily designed for DC service require design features to increase the total arcing voltage. This can be achieved by designing larger single air gaps and multiple gaps in series, or by using magnetic fields to force arc movement.
The following is from a Eaton document for their solar DC disconnects.
https://www.youtube.com/watch?v=Zez2r1RPpWY
Why does 220VDC arc like that? Is that really 220VDC? Looks like a LOT more.
Are you asking for a document showing that Don is amazing or a document showing that what Don said is true?
If the former, I think his Mom wrote one up!
I want a document that verifies Don's mom stated that what he said is truly amazing. Preferably notarized and such if possible.
Yes it's listed AC or DC.
DC has no zero volt crossing like AC to "assist" with extinguishing the arc.Why does 220VDC arc like that? Is that really 220VDC? Looks like a LOT more.
