What is this?
PaulMmn
Union, KY, USA
Are all 3 of those things prongs to plug into an outlet? Are the 2 on the left polarized (ie one blade wider)?
Does the odd prong on the right connect to either of the other 2?
NTesla76
IA
As far as I can tell, all of the prongs are the same size. The prongs aren't removable. I
480sparky
Iowegia
It's a device Leviton produced to test the function of TR receptacles. If you could push the two blades in but not the one, it's a TR.
Dennis Alwon
Chapel Hill, NC
Electrical Contractor
Ken got it correct. It is not connected to anything but merely a test of the TR receptacles. If the one prong side goes into the receptacle then the TR part is not functioning.
PaulMmn
Union, KY, USA
If you like strange things.... This isn't Leviton, but it's an interesting idea. I searched for Leviton Adapter, and this was in the mix.
7-way lightbulb expander.jpg They also make a 3-way and a 5-way adapter!
Hv&Lv
Engineer/Technician
View attachment 2551529 They also make a 3-way and a 5-
way adapter!
wow... I can just see someone getting this and putting 7 60 watt incandescent bulbs on that 60watt keyless socket..
I noticed on the picture the lights are led or CFLs
