What is typically the operation to access an underground easement utility primary line if the pad mounted transformer is far away from it?
For example, if you have an underground easement running and you try to tap it - do you need a a pad mounted transformer nearby it?
what type of accessible junction box do they use if the building utility transformer (for example 150' away) is not nearby the underground easement pathway. I'm just trying to get a rough idea how the connection between the underground easement and a transformer that is far away is being connected directly on the primary side.
Thank you
Thank you
