nerspellsner
Under 345000 volt power lines, there is an electric fence surrounding a horse pasture. The owner complained about getting shocked when he touched the fence with the fence controller unplugged. The power company installed data recorders at 5 points along the fence. There is between 400 volts and 800 volts on the fence coming from the overhead lines when the fence is off. The power company recommends grounding the fence when it needs to be turned off. The fence needs to be turned off daily. Instead off connecting a wire to it every time to ground it, a switch to open and close the ground to the fence would be much easier. I was laughed at when I asked for a 1000 volt knife switch. I need a high voltage switch but only milliamps will flow through it. Any ideas? Thanks.
