but... two prongs can make a light...Two wrongs won't make it right.
Two wrongs don't make a right, but three rights make a left.but... two prongs can make a light...
You beat me to that one. It's amazing the look on people's faces when you tell them that. It usually takes about 5-10 seconds before it hits home.Two wrongs don't make a right, but three rights make a left.![]()
What say ye? I preformed the rough in inspection and assumed that this was a receptacle outlet, on the final it is a switch. How would you handle this?
An Easy fix for sure.This would be an easy fix, house has a basement and panel box is right below
If there is a neutral inside the JB convert it to a switch over receptacle. However, if it's 15A circuit then you have another violation.![]()
