NEC 230.49 states ug service entrance conductors are to be protected against physical damage according to NEC 300.5. NEC 300.5 states "where the enclosure is subject to physical damage" use rigid metal, imc, or sch 80 pvc...to a point 8 ft above finished grade. Also restated in NEC 230.50. In NEC 300.50.....conductors emerging from ground shall be enclosed in listed raceways. Raceways on poles shall be rigid metal, imc, or sch 80.....to a point 8 ft above grade. What locations are subject to physical damage? 1.)utility poles / service poles 2.) service installations mounted on meter structure 3.) service installation mounted on 4.) service installation mounted on the side of a building
