I am designing an electrical control panel requiring 100A max. Takes two sources, 115VAC and 240 3phase. It has a disconnect switch, controller, AC/DC power supply, and relays. I am leaving it up to the end user to accomodate protection breakers or fuses based on given load requirement.
I had the design tested by 3rd party for safety testing for CE & UL certification. One recommendation from the lab was to require AIC rating.
First question is, Do I really need AIC rating label? If so, what should it look like? Size? How do I derive AIC rating? Most components inside do not have AIC rating.
ref:
http://www.abb-control.com/pdf/white/LV046.pdf
ref:
