If I have (2) parallel sets of 4/0 cables running in two seperate conduits on a 4-wire system do I need to pull a neutral with each one of the feeders.
This feed is between the inverter and main connection panel I have referenced in another thread. I was going to size the neutral based on 250.122 and pull one with each feeder however I dont know if I need to pull both? Any recommendations?
In conjunction with my other post I'm assuming that these neutral conductors would be seperatge from the combined grounding electrode conductor (GEC) that I need however would the neutral be bonded to the GEC at the main panel?
Thanks.
Thanks.
