Stevenfyeager
- United States, Indiana
- electrical contractor
My customer has two 200 amp panels, and thinks his house he just bought has 400 amps, and wants me to add quite a bit of loads. But I have seen houses have 200 amp panels before and yet have only 200 service. The meter base is a large, 400 amp sized one. But, the conduit coming up from the ground is only 2 inch, which around here is not large enough, they always require 2 1/2 to 3 inch. So I called the POCO. They have it listed as a 200 amp service. (We are not allowed in IN to remove the meter.)
What determines the service amp size anyway ? Is there theoretically an 'infinite' amount of amps available from the pole, limited only by the main breaker in the house ?
Thank you.
Thank you.
