Minuteman
- The Sooner Nation
If a CFL Breaks - Warning:
How should I clean up a broken fluorescent bulb?
EPA recommends the following clean-up and disposal guidelines:
1. Open a window and leave the room (restrict access) for at least 15 minutes.
2. Remove all materials you can without using a vacuum cleaner.
Wear disposable rubber gloves, if available (do not use your bare hands)
Carefully scoop up the fragments and powder with stiff paper or cardboard.
Wipe the area clean with a damp paper towel or disposable wet wipe.
Sticky tape (such as duct tape) can be used to pick up small pieces and powder.
3. Place all cleanup materials in a plastic bag and seal it.
If your state permits you to put used or broken CFLs in the garbage, seal the CFL in two plastic bags and put into the outside trash (if no other disposal or recycling options are available).
Wash your hands after disposing of the bag.
4. More
The first time you vacuum the area where the bulb was broken, remove the vacuum bag once done cleaning the area (or empty and wipe the canister) and put the bag and/or vacuum debris, as well as the cleaning materials, in two sealed plastic bags in the outdoor trash or protected outdoor location for normal disposal.
For more information please see The EnergyStar CFL Mercury FAQ
http://www.onebillionbulbs.com/cfl_cleanup
Copyright ? 2007 Pajamas Media. All rights reserved.
4. More
