arizonamaddy
I work for a condo convertion company that is looking at a property in L.A. California. It is currently an apartment complex and each unit has a 60amp breaker panel. The site was not origionaly built with a dedicated circuit for a microwave. There is a vent hood and the current owners have replaced some vent hoods with micros. My question is if this is up to code or what it takes to bring an item like this up to code. The unit has a 60amp panel with no H/W tank no laundry service and the range is gas. The second parts of the question are, what is the maximum voltamps for a 60amp main and if I had to replace a panel will I have to change it to a 100amp panel to be code compliant.
Thank You All.
Thank You All.
