What to do with neutrals?
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
MV service switchgear, with a main-tie-tie-main configuration. Utility connects to far left and to far right. Generators connect between the ties. Utility does not include neutral. Generators do. Only loads immediately downstream are step-down transformers (no neutral needed).
How are the neutrals to be connected?
  • Disconnect at generators and don't bring to service panel?
  • Add neutral bar to service switchgear, connect generator neutrals there, and connect nothingbelse there?
  • Something else?
