Checking on some work done by a non licensed person and found this. last Panel in line has ground and neutral bonded together. 2- 5hp air compressors Each on their own breaker 1 a 240 volt 30 amp, the other a 240 volt 20 amp breakeR. I found the wires for the compressors and 3 other 20 amp single pole circuits in the same conduit.In the other conduit I found 4-20 amp circuits run together with 1 #8 run for the neutral. This job was done by non licensed person who claimed he could do the job for what i had bid in material alone.any thoughts on what to tell customer would be great. the reason i know about this was i was called to fix a tripped breaker that wouldn't reset. found nicked wire Uf that was taped over and reburied.
Thanks drwill
ps i from Texas and we have state licensing, and where this work was done has gone for years without havinng to use licensed electricians.
Thanks drwill
