brother
What type of Insulation is Knob and tube wiring?? is it RHW? TW? Im just curious thanks.
brother said:What type of Insulation is Knob and tube wiring?? is it RHW? TW? Im just curious thanks.![]()
LarryFine said:It can be almost anything; K&T describes the hardware and method, not the insulation type. See Art. 398 and esp. 398.104 ('02 NEC).
brother said:Ok let me put it this way, what is the MOST COMMON they used in these old houses???
ceknight said:Around here, it's usually cloth-covered rubber insulation.
LarryFine said:Yes. Now, what type would that be? Dunno.
ceknight said:I wanted to be more helpful, but couldn't. Almost every house I work on has some vestigial knob and tube wiring in it, heck, my own house still has some. I've ripped out miles of the stuff, even some in remarkably good condition, and have yet to see a visible marking.![]()
georgestolz said:In my folks' house, I ran across some cloth-covered two conductor cable. What is the technical term for this stuff? It had a black and a white conductor in the cable.
You really don't get out much, do you? (Just kidding)georgestolz said:In my folks' house, I ran across some cloth-covered two conductor cable. What is the technical term for this stuff? It had a black and a white conductor in the cable.
This appeared to consist of 14 AWG copper conductors, and they were on a 15A breaker. The connections at the receptacle were good, but there were indications of heating on the neutral, for about an inch from the receptacle. What could cause this?
gndrod said:Southwire holds the ROMEX trademark since buying the rights from General Wire.
I didn't really think about the plug blade contact, thanks Larry!LarryFine said:The heat damage is from a loose connection, either the wire-to-screw connection or the plug-blade contact inside the receptacle.
hillbilly said:I believe that the outer woven cover on that NM is asbestos. If I'm not mistaken.
steve
