rt66electric
- Oklahoma
What would be the best way to wire-up heat tape in a propane filling area?
I have a customer that needs a heat tape added to a Vacuum pump. (cold weather/oil is creating high amps overload).
Would a simple EXP switch, and, then connect the heat tape (through a CGB) into a round EXP screw cap box be sufficient? Where would Seal-offs be needed?
Thank you for your time
Dennis
Dennis
