I am not asking this question to use actual numbers you throw out, I plan to do this job mostly free for a friend. But I was curious IF I was in business for myself what I might charge.
Customer needs a 3-wire range run upgraded to a 4-wire(range manual gives no indication a 3-wire is OK to use). This job will involve about 25 feet of 6/3 through a crawl. And I mean crawl, and a little nasty but not terrible. At the range will require a new surface mount box and receptacle. Getting up into the panel looks pretty easy as there is a chase up to a surface mount main panel.
So I'd say if I had all the materials and things went smoothly I could do the job in 2-4 hours. But at say $100 per hour, this just doesn't seem worth it to crawl around in the dirt.
If you had this simple job, how would you bid it? Would it be $500? $1000? $1500? More? I have no idea. I read a lot on here about making sure to charge enough so I just am trying to get an idea how to do that. My brain gets pretty stuck on hourly as that is how I have worked my whole life.
Again, this is just an exercise to gain info about pricing. Let me know what other details you might consider.
