busman
- Northern Virginia
- Master Electrician / Electrical Engineer
All,
Customer just bought a 1939 house (no home inspection). The place is an encyclopedia of NEC violations. The main panel is split-bus with 4 2-pole in the top half (one is the 60 amp to the lower half). The other two poles spots in the upper half are single poles (an obvious violation of the 6 disc. rule). The lower half has all but 2 locations filled with double-up breakers. I believe I convinced her that a service upgrade is required. In the mean-time I have been troubleshooting other peripheral problems (no GFCI's in bathrooms, receptacles painted over, etc). There is also a sub-panel fed from the lower half by a 30 amp breaker. The sub has four 15 amp circuits in a six space MLO.
One of the things she wanted was to change the gas clothes dryer for electric. I told her a few days ago that this was not practical/possible given the full nature of the main panel and the small sub-panel.
When I show up today - there is the electric dryer on a 30 amp 2-pole in the sub-panel. It is run with 10-2 WG. A violation of the neutral grounding rules. Not to mention that the dryer is using the entire capacity of the sub-panel.
I told the customer that I was upset that she disregarded my recommendation and asked who did the work (thinking it was the appliance installers). Turns out she had a friend-of-a-friend do this work. My first instinct was to walk-off immediately - in fear that my work was being mixed with obviously unqualified work. I finished the job I was working when I found this, but my gut reaction is to tell her to find another electrician and document the hell out of the exact work I performed there.
Your thoughts?
Thanks,
Mark
[ August 21, 2005, 09:43 PM: Message edited by: busman ]
Your thoughts?
Thanks,
Mark
