memyselfandI
- Hampton Roads, Virginia
I have a question. I was called to a residence by a real estate agent who said the tenant had a fire in the house. Thinking the worst, I went to the place and found that the fart fan in the bathroom had caught fire. The fire was in an area about the size of a serving platter for a party, about 12"X18". The fire department was called and they turned the main breaker off at the panel and place a tag on the panel. To summarize what the tag said is " power cannot be restored until the defect or equipment has been repaired. Some local authorities may require a permit and inspection prior to the removal of this tag." I also noticed on the tag that they were unable to isolate the circuit. It just so happens that the circuit breaker that was tripped in front of them was the one that was feeding the bathroom lights. So I researched the problem and removed the damaged piece of equipment and noticed that there were other wires in the attic that IMO were not safe. They were not in the circuit that was in question, but I couldn't sleep well knowing I left that in the attic in the condition that it was in. I repaired the wires and restored power to the unit. I was required to obtain a permit to replace the fan. After obtaining the permit I replaced the fan and called it in for an inspection. The chief inspector called me and said that he knew that I had did the work, but that I was to contact the fire department so they could inspect it to restore power. Now don't get me wrong and God bless every firefighter out there, but one problem that I have with this is that if power restoration was a concern, then why wasn't the meter pulled? As a licensed and insured electrical contractor, IMO I believe that I am qualified to determine whether a circuit that was damaged in a fire, and after all the appropriate measure were taken to repair the problem, can be restored at my discretion and I accept full the responsability. I never removed the tag either.
I spoke with another inspector in another city and he said that in his opinion he didn't see a problem with me restoring the power because I am licensed and I took responsability when I restored power. He said that if there was a concern that the fire department would have pulled the meter so that it was impossible to restore the power without it being cleared by the city.
Here is my question. Did I overstep my boundries in restoring the power? What would any one of you had done, especially you people who live in the South where the heat is a problem? I appreciate any feedback
