timmermeier
- alton il
- electrician
What year did aa8000 aluminum wire become available ? by NEC  can use aluminum wire to wire a house ? ( not local codes but the NEC )
			I don't know what year it became available, but if you can find aluminum cable, I believe you can wire a house with it.What year did aa8000 aluminum wire become available ? by NEC can use aluminum wire to wire a house ? ( not local codes but the NEC )
You just can't use NOS, new old stock NM sheathed AL cable, since NM sheathed cable is required to have 90°C conductors, & NM cable has 60°C conductors, (NM-B has 90°C conductors).I don't know what year it became available, but if you can find aluminum cable, I believe you can wire a house with it.
Ron
Yeah, I should have been clear that if anyone made AA8000 aluminum NM cable, you could wire a house with it.You just can't use NOS, new old stock NM sheathed AL cable, since NM sheathed cable is required to have 90°C conductors, & NM cable has 60°C conductors, (NM-B has 90°C conductors).
The UL product standard for aluminum conductors required the use of the AA-8000 series alloys starting in 1972 or 1973.What year did aa8000 aluminum wire become available ? by NEC can use aluminum wire to wire a house ? ( not local codes but the NEC )
