I think those are Polaris connectors, and all they would be are splices. Ie, solid electrical connections between conductors.
It appears that two branch conductors are being fed from one circuit breaker. Instead of trying to land both wires on the circuit breaker, they landed them in a splice terminal and pigtailed up to the breaker.
Looks like to me the original feed (bigger of the 3 wires) was maybe pulled off of the main in that panel and spliced, tapped to the other wires. (One set of the smaller wires) re-feeds that panel and the others appear to exit through the other pipe on the right and maybe go on and feed something else making that a tap.
Could use a few more pictures so we can maybe follow the wires out.
I'm thinking that if this tap had been done in a trough it wouldn't look at all odd.
They are feeding this panel and something else (probably another panel) and they have CTs and wish to monitor the power of this panel.
Again if you were to see this done outside the panel in a trough you wouldn't think twice about it.
Why would they run wires like this?Any idea?If it was in a trough its much easier to understand but here its confusing...Do you know why they would install wires like this?
That's why I thought maybe those wire had originally been landed on the main breaker. Just my thinking. Saved a piece of wireway and nipples.Why would they run wires like this?Any idea?If it was in a trough its much easier to understand but here its confusing...Do you know why they would install wires like this?
The wire connector at the end of the three orange-taped wires...What are polaris connectors?What are they used for?
...and the like are used for splices and/or taps. The one pictured is actually Ilsco brand. There are three in the panel, one for each leg.
Slang wise, I suppose you can call 'em bugs... but in my mind they are not. To me, a "bug" is an old-school splice or tap made up using a split-bolt connector and taped up in traditional manner (that's another story :happyyes.
PS: Note the wire in the middle is larger (at least it appears to be). As such, it is likely a feeder and the other two [seemingly] smaller wires would be feeder taps.
I hope you are not working in that panel without some protective gear.
Thanks for clearing it up for me regarding the Polaris connectors..Was scratching my head...:thumbsup:..As far as the connection goes i think what you are saying is the bigger of the three wires maybe coming from somewhere and the other two(smaller sizes) may be taped from the bigger one?If that's the case where does the tap happen?Inside the connector?And as far as i was looking at the panel board one of the smaller wires go to the main breaker and other tapped wire goes out to feed something else?
All these connections happen inside of the connector?
+1Yes.
