jeff43222
- Minneapolis, Minnesota
Here's one for the more experienced members:
A couple of times I've come across lighting in residential occupancies where the light switches are connected to a transformer/relay system via low-voltage wires, and the relay system then powers 120V lights. In one case, all the light switches in the house consisted of a single push button that controlled on/off (like the power button on a TV). When the button is pushed, you hear a loud click coming from the attic. The click sound always comes from the same location, which, I'm guessing, is a transformer/relay center.
Just yesterday in another house, I saw a similar switch with a selection dial next to it. Apparently you dial up which light you want to switch and then push the button. Down in the basement I found a junction block of sorts, with a whole bunch of low-voltage wires connected to it (one pair for each tick on the selection dial), and the block was connected to a transformer.
Both of these systems were installed in the 1950s. I'm curious if this type of wiring method had a name.
