Eddy Current
I couldn't find anything but i have also forgot what the code defines as a panel. 3ft?
I couldn't find anything but i have also forgot what the code defines as panel. 3ft?
A panel is no different from any other enclosure in that respect.I couldn't find anything but i have also forgot what the code defines as a panel. 3ft?
Usually the code states ".... should be securely fastened in place every "X feet". In addition each run between termination points shall be securely fastened within x' of each outlet box, jb, device box, cabinet, conduit body..." A panel would be a cabinet in this case.
Ok, also there is the secured on four sides thing.
Are you still talking about pipe? Or Boxes?
