What's this?
physis
I don't know if this is all that related to the forum but I can't figure out how to read this and I thought I'd ask you guys if anyone knows what it means.
Re: What's this?
I'm not familiar with this type of signal processing, but here's my best guess.
It either means that the:
frequency begins at time 0, with a range of 1 to 50, and as it approaches 100 seconds, its range is much smaller centering around 23 Hz or so. In addition, at time 0 the amplitude of the signal is 0 and increases with time.
The other way of seeing it is the amplitude begins at time 0, with a large range and as it approaches 100 seconds, its range is much smaller. In addition, at time 0 the frequency of the signal is 0 Hz and increases with time to approx 40Hz.
The graph is not well labeled.
Re: What's this?
Thanx ralph,
Guess I can put all my books,vhs tapes,cdRoms,jr high school crib notes and dyno sheetprint-outs for my motorcycle away now..whew.. :D
Re: What's this?
The 'quadratic chirp' in the above spectrogram is actually the Red Line that sweeps from bottom left to top right.
The black line that Ron is describing appears to be a WAV file byte that is drawn or layered on top, so that would explain the possibility of being an Album Cover.
Re: What's this?
Ever seen the spring type "door stoppers" a lot of people have in their house? The type that mounts on the wall behind the door, and the door hits the spring before it hits the wall.
My 2 year old son loves to pull the spring sideways and then let go. The spring bounces back and forth making a sound that I'm not going to try to describe.
Anyhow, at first the spring makes large slower swings. And as time goes on, the swings are smaller, and faster. I think that's what they are showing.
The red line shows the base frequency starts at zero, and goes up to 40 hz. I assume the other colors are amplitudes of harmonics in some way. And for my spring example, the black line would be a graph of position vs. time.
Or it may be a record cover!
Steve
Re: What's this?
Steve66 gives us the perfect explaination -- I'll only add that the noise it makes is "booooooiiinnnng".
Please watch that your 2 year old doesn't eat the plastic piece on the end of the spring -- these are notorious as choking hazards.
Re: What's this?
This is the site it comes form. It's very doctored for a graph but I think the album cover (although a valid guess) is likly not it.
You can always right click an image and find it's url under properties.
